The washer will not start and displays an error code E41. The door strike appears to be OK. The service spec sheet says to do Test 7 and check continuity on J2 of the control board (if closed = replace control board, if open = replace door switch). I get a reading of 100k ohms, but I was expecting it to be infinity if open. Maybe my meter is off? I am thinking the control board is OK based on this reading. I also checked the resistance of the door lock assembly "PTC" (which I assume is the connector that the J2 cable connects to). This reads about 1800 ohms, which according to Test 9 is in the neighborhood of being correct. Should I replace the control board (137006000), the door lock assembly (AP4455026) or my meter :)? Or is there anything else to check?
Thanks for any assistance!
