Error Code E41 & Door Switch Already Replaced
I have a 5 year old Frigidaire Front Load Washer (Model# GLTF2940ES3) that just stopped spinning. It is draining fine, but leaving one or two sopping wet things that are on the very bottom of the wash load. We checked the internal hose for any clogs-no clogs, we just changed the door lock assembly and it still won’t work. When we test the codes E41 still comes up. If anyone could please advise of a way to fix this it would be greatly appreciated, thank you!
The tech notes inside the lower service panel tell you how to put it into diagnostic mode and generate error codes and test components. Focus on the motor/speed control board.
e41changed board now gettin same problem with e5e co
de
