Washer will not rinse or spin
Hello, I have a Frigidaire Affinity front load washer which just started acting up. It no longer rinses or spins. I took the washer apart and cleaned the drain hose and drain pump. Still does not work. The error code is E43 which apparently means the controller board is defective. Anybody else have this issue . . . solution?
When the washer stops the door lock light is on so I am assuming the door latch is ok.
Any help would be greatly appreciated.
Kev
