front loader frigidaire will not spin in wash cycle
my front loader washer does everything but spin in wash cycle (I went into the test and the washer did spin, But when in regular cycles it will not spin fault code is e43 I did take the drain boot and filter off and cleaned it I also cleared the fault after that, and then unplugged for about 8 seconds and restarted, still will not spin . I have read it could be the door switch or control board what would be my next step?
Unfortunately your next step is to start replacing parts and see if you can find a replacement that fixes things. I would start with the speed/motor control board.
If you buy from this site you can return parts you do not need.
