I’ve Gone Thru About 250 Posts And Although Similar Ours Varies Slightly. The Electric Dryer Heats When It Is First Turned On. Then About 5 Minutes Or So It Cools Down And No Longer Heats. I Have Cleaned The Vent FROM End To End. Whats Next?
I would recommend to check the blower wheel and replace the cycling thermostat. If you need the correct part number for the cycling thermostat, post the serial number.
Here are the break down diagrams for the Maytag dryer http://www.appliancepartspros.com/partsearch/model.aspx?diagram_id=1343831&&model_id=5176992
You probably checked the cycling thermostat for continuity and this test does not prove that the thermostat is reading temperature properly. Thats why I would recommend to replace it. The part under this thermostat is a thermostat heater which works when you set a lower temperature. It is a good idea to replace them together.
The part number for the cycling thermostat is [AP95868](http://www.appliancepartspros.com/partsearch/ctrfs.aspx?part_id=95869&&&diagram_id=1343831&model_id=5176992"]AP95869[/URL]
The part number for the thermostat heater is [URL="http://www.appliancepartspros.com/partsearch/ctrfs.aspx?part_id=95868&&&diagram_id=1343831&model_id=5176992)
Did you check the heating element as recommended by denman?
When I seperated the thermostat from the heater there was a small burn spot on the heater. replaced both and everything works fine. Thank you guys for all the help. Have a Happy New Year.
Hank
You are welcome. We are glad you were able to fix it. Happy New Year!
Dryer will not start. worked fine put load of clothes in nothn. it has power just wont turn on. any idea’s dryer is only 5 years old i really dont wanna replace it :mad:
— Begin quote from dkginster@comcast.net;134447
Does it make any noise at all when you try to start it? The unit does have a thermal fuse on it, that can keep it from running, so that’s a possibilty.
the button u push to start it makes a humming noise but thats it. and will have hubby check the thermal fuse TY
— Begin quote from dkginster@comcast.net;134453
If the hum is coming from the motor have him check to see if something may be stuck in the blower, which is attached to the motor. If it’s the motor humming and not starting, that isn’t a good sign if nothing is stuck in the blower.
its not really a humming noise lol its more like the noise of the button turning haha sorry @ being so blonde.
okay we wired the 2 wires on the thermal fuse together and the dryer works .Is the one that you showed me the correct one for our dryer ?
thank you so much for your help.
— Begin quote from dkginster@comcast.net;135028
Yes it was. Glad you got it going.
