Okay…I have tested a number of items and it appears the issue is the thremal fuse. The problem is the location of this item, it is located directly below the heating element and appears to be attached to the bracket.
How can I remove this fuse…and replace? Is this fuse purposely placed in the most difficult area? Everything else seemed somewhat easy to access.
