I have never been able to run the self cleaning mode on this appliance. every time I try it it always shows F1 ERR and the heat goes off. This usually happens about 1 hour into the cycle. I then turn off the power and when i power it back up it resets. Today it wouldn’t reset and the F1 ERR came back on so turned the power off again and left it off for a few hours while i searched online for the EOC which the manual says i need to replace. 165.00 no problem, but when i powered it back up after a few hours it reset and we are able to use it. I know however if I were to try and run the Self-cleaning mode that it will F1 ERR. Any help would be appreciated. tony
Related topics
F1 failure code in self clean mode only | 10 | 8073 | May 7, 2012 | |
Self Cleaning | 1 | 1002 | May 22, 2010 | |
Self cleaning oven error for Frigidaire Professional series electric slide in oven | 1 | 744 | March 6, 2015 | |
Self Cleaning and F9 error | 1 | 5209 | May 20, 2008 | |
Error code shows up after using self clean feature | 0 | 2482 | November 11, 2008 |
