Electric oven will not hold temperature evenly
Hi,
I need some help in repairing my double oven. The lower oven works fine, it holds whatever temperature I set it to. The upper oven is a different story, it will not hold any temperature I set. It varies quite a bit, usually -35 degrees or so. I just replaced the sensor tonight on the upper oven. it still varies from -35 degrees up to the set temp. Any help would be appreciated.
[SIZE=3] [/SIZE]
regards
ed
