electric oven
Hello, I have a whirlpool oven and the bake element and broil element do not work or just stopped workimg. The elements ohm out at 25.1 so I am assuming that they are good. I am wondering if it could be the sensor but how can i check the sensor, or does anyone know what my problem might be
:confused:
I have the same problem with my Oven. The fan works, warmer does not, and the oven does not heat up. I tried finding the fuse, but could not locate. I really hope it was not replacing the control panel. I put a voltmeter on the red wire coming from the control panel and there was no voltage reading.
