Whirlpool Electic oven Bake and Broil is not working. The microwave works fine.
Hi,
I replaced the door latch assembly for this. I am still not getting my bake or broil working. In the panel I am not seeing any error codes. I removed the bake element and checked for the resistance. It is showing 28 ohms as per the tech sheet. I connected the power and turned on the bake cycle and checked the voltage to the terminals to the bake element. I got nothing. I checked the Thermal Fuse. It showed continuity. I checked the resistance of the Broil element. It also showed 18 ohms as per the tech sheet. I don’t know how to proceed further. Any suggestion or help is appreciated.
