Glass top range works but oven died, digital control panel is blank. No broken heater elements they have continuity and correct ohms, temp probe also checks ok with ohms.
What made the loud pop :eek: ?
Control panel or something else?
Based on the information you provided, it sounds like the electronic control board has failed on the unit. Test and see if there is power coming to the control board and if so, replace the board.
