whirlpool dryer has been messing up started not heating up then after a couple times restarting it it would heat up . now its not heating up at all just blowing cool air out. hate to have to call a repair man to fix something simple and charge out the but when its prob something simple and cheap. it goes through its cycle and buzz’s when it s done just doesn’t heat up…before could touch outside of dryer and feel it was warm now its always cold .
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=wed5100vq1
Unplug the unit and check the heating coil with a meter.
Should be in the 8 to 12 ohm range.
- Always remove power from the machine otherwise you could blow your meter.
- Always disconnect at least one side of any device you are checking. This eliminates the possibility of measuring an alternate/parallel circuit path.
- When checking for closed contacts and continuity use the lowest scale (Usually 200 ohms). Then try higher scales. This scale is 0 to 200 ohms so if the device you are measuring is 300 ohms this scale would show an open circuit which it is not, you are just measuring outside the scale’s dynamic range.
- When you start always short the meter leads together. This will tell you that the meter is working and if there is any 0 offset.
