While troubleshooting a draining issue, I disconnected the wires to the water inlet pump. I did not take note of the wiring configuration and now hot water runs when set to cold (and vise-versa) and the washer does not stop at the end of a cycle - it starts over. Can anyone help me reconnect the 4 wires in the proper configuration?
You can either switch the hose connections or switch the connections at the valve assembly to fix the one problem. I don’t have this unit in front of me, but usually the hot water connectors are red.
The other is more difficult, probably the timer.
i think the switch is bad on the ice dispencer i put a new motor in it only thing left is the switch cant get the pannel off the door to check switch how do i get it off without breaking it
