Kitchenaid dishwasher
Kuds50SVSS4
Element not heating
Element tested- 13ohms - good
Power supply to element tested - 120V - good
Dishwasher rated at 1100 watts
Only component between element and control board is the thermostat which reads 0.0 to 0.1 , so its good.
Is anyone aware of what I might be overlooking in this situation?
Thank you.
denman
3
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=Kuds50SVSS4
Sounds like the control board is shot.
I would check the heater circuit at the control board before replacing it. Just to be sure that there is not a bad connection/wire in the circuit.
P3 to P9 at the board should give you the 13 ohms.
