KitchenAid Dishwasher, Not Heating
Hi Everyone, I am trying to get some help with a KitchenAid Dishwasher, Model KUDE60FVSS2, that is having problems with the heating elements.
I have done the following:
[LIST=1]
*]Replaced Heating Element
*]Replaced High Limit Thermostat
*]Rebooted the Control Board
*]Visually Inspected Control Board (No burns, loose wires)
*]Tested Continuity between Control Board and Heating Element
[/LIST]
What continues to happen is:
  1. During Normal Wash cycle/Hi-Temp Scrub/Sani-Rinse: The water stays cool, heating element does not turn on. It should heat the water to 155 degrees on the Sani-Rinse.
  2. Heat Dry: The heating element does heat up to 400 degrees, but the dishes are so cold and wet that they do not dry at all.
So, any idea why the water not heat up during any of the wash or rinse cycles?
Is there anything else to try before looking at replacing the Control Board?
Thanks for any advice you might have!
Michael
