My oven went from E2 F3, to E0 F3 after I changed my sensor, what can I do next.
Here is the tech sheet
http://www.servicematters.com/docs/wiring/Tech%20Sheet%20-%208301758.pdf
I would check the wiring to the sensor first.
Then check the resistance of the new sensor with a meter. Could be you received a faulty sensor.
If all OK then the most likely culprit is the control board.
— Begin quote from denman;280829
Thanks I will try these things and see whats what. Thanks again.
