Error Code E5e
Hello Wondering If Any Body Knows If The Control Board Or Speed Control Should Be Replaced With This Communications Error Occurring To The Manual Both Are Very Expensive But Every Thing Runs On The Washer Except The Tumble And Spin. It Might Be The Motor Or One Of Theses Boards Any Advice Or Suggestions To Fix This Or How To Test What The Problem May Be Exactly?
The only real way to tell is to replace the part and see if that fixes things. The high probability is that it is the speed control board, so that is what I would do first. Also check the wiring and the door lock assembly.
If you order from this site and the part does not fix the problem you can return it, see the Returns policy for requirements.
