As the washer fills with water (wash cycle), within the first couple of seconds starting, it triggers an error code (F1) twice. I press stop and then start again for these two episodes. Again, as washer fills for the rinse cycle, the error code (F1) triggers twice. I follow the same procedure - press stop, then start each time it triggers. After each of these beginning episodes, the wash and rinse continues without interruption.
What do I need to do to correct this problem?
