Kenmore Elite Washer F1 Error Code
Kenmore washer machine began displaying F1 Error Code. What is the reason for that error code? What part do I need to replace?:eek:
Under the top is a set of tech notes which you can use to interpret the error codes and do some diagnostics. Your error code indicates a main control unit failure.
thank you for your response
— Begin quote from sidfink43;460657
When stuck in the F1 mode is it full of water?
