washer
The washer started giving us an F 06 error code intermittently at time a month or so ago.We were able to select a different wash cycle that it would complete without this error code,but now it is coming all the time .Do you have any idea?Model # 110.45081401
Your model number is incomplete. You can research your F code by either pulling your manual out or tech sheet usually behind the touchpad. Research your F code with a google search with your model number. Not all F codes for Kenmores are the same.
