Kenmore Elite Calypso F1 error
Any help Can someone please tell me what this code means?
is very much appreciated!
Thank you.
As you can see from this manual, the F1 code is not listed, so we are as much in the dark as you are. In other Whirlpool machines of this type the F1 code can mean replacing the control board, so you might want to try that.
Look closely and see if it is not the FL code, which is explained.
http://www.managemylife.com/mmh/lis_pdf/OWNM/L0407407.pdf
