Error Code FE
I am getting an error code FE on my dryer which stands for Improper / irregular power source. Nothing has changed in my setup it is still plugged into the same outlet the last 4 years, and the washer is connected to the same outlet and works fine. Any ides what may be wrong or have to be replaced?
Bad receptacle?
