Error Codes
I recieved error code F2 E6 and was told by Whirlpool to replace the the control board which I did.
After replacing that part thern I get error codes F2 E1. Which states that I have to replace the Keypad.
Is this out of the ordinary that both parts become defective at the same time? What would cause something like this? If I replace the keypad will this fix the problem or should I be looking for something else.
I would really like to order the parts so we can use the oven.
Ed
Check the conntectors to the keypad they sometimes get corrosion on thm causing the same effect.
Nat
It i possible that a power surge could have affected both parts. If memory serves…just check for continuity. I’ll try t do some research and see what I can find for you.
Nat
Nat
Nat
Did you find anything out about this?
Ed
