Where can I obtain a list of the error, or fault, codes for my washer. I keep getting error codes and have to reset requiring "baby sitting" the washer to get it through all the cycles. F1 and F24 codes are the ones I get. I would like to fix the problem if I could find what the codes mean.
Look under the top of the machine, there should be tech notes that will explain the codes and tell you how to do some testing.
