getting f-2 codes
— Begin quote from eigpm;427176
getting f-2 codes
Eig,
The tech sheet for your unit states that the F2 fail code is a failure in the touchpad assembly.
In your case, you would need to order the ERC/Clock assembly, It is a single piece unit.
[part]AP3969156[/part]
[SIZE=1][FONT=Swiss721BT-BlackCondensed][SIZE=1]F2 [/SIZE][/SIZE][/FONT][SIZE=1][FONT=Swiss721BT-RomanCondensed][SIZE=1]Shorted key[/SIZE][/SIZE][/FONT]
[LEFT][SIZE=1][FONT=Swiss721BT-RomanCondensed][SIZE=1][FONT=Swiss721BT-RomanCondensed][SIZE=1][FONT=Swiss721BT-RomanCondensed][SIZE=1]1. Verify failure, if not displayed, and clear the error code by pressing the START key.[/SIZE]
[SIZE=1]2. Unplug range or disconnect power longer than 30 seconds.[/SIZE]
[SIZE=1]3. Plug in range or reconnect power.[/SIZE]
[SIZE=1]4. Observe for longer than 1 minute.[/SIZE]
[SIZE=1]5. If failure remains,[/SIZE]
[SIZE=1]6. Unplug range or disconnect power.[/SIZE]
[SIZE=1]7. Replace control.[/SIZE]
[SIZE=1]8. Replace all parts and panels before operating.[/SIZE]
[SIZE=1]9. Plug in range or reconnect power.[/SIZE][/LEFT]
[SIZE=1]10. Verify operation is normal.[/SIZE]
[SIZE=1]Good Luck,[/SIZE]
[SIZE=1]
[/SIZE]
[/SIZE][/FONT][/SIZE][/FONT][/SIZE][/FONT]
