Error code F2
Can anybody tell what error code F2 mean? It appears on the control panel for the whirlpool GBD277PDB5 double wall oven when I try to start the oven
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=GBD277PDB5
The tech sheet gives the error codes.
Try unplugging the unit for a few minutes to see if the error will reset/clear.
If not then perhaps try the following especially if it also gives a E1, E5 or E6.
Connector Cleaning / Checking
Unplug the unit
Open it up
Clean the edge connector. Use electronics contact cleaner or isopropyl alcohol.
If the above does nothing then I would replace the keypad first.
Note: There is not a good way to check it as they do not publish the keypad outputs.
