I have a Whirlpool Duel Built-In Electric Convection Oven (Model # GBD277PRS01; bought in 2006). I just got error message saying E6 F2. So I took the power off and took the control panel off the unit. I waited a couple of hours and the control board now says E1 F2. Should I replace both the panel and board? Suggestions? I look forward to your reply and help!
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=GBD277PRS01
I cannot say which part is bad.
The errors are basically the same.
I would go with the control panel first.
Note that if you purchase it from AppliancePartsPros you can return it if it does not fix the problem.
Please see their return police.
Perhaps try the following before ordering anything.
Connector Cleaning / Checking
Unplug the unit or flip the breaker off.
Open it up
Clean the edge connector. Use electronics contact cleaner or isopropyl alcohol.
