New Error Code on Whirlpool after service
Was getting the E3 F2 code and had the control panel replaced yesterday. Today, I’m getting a new error code - E0 F2. Any thoughts?
Here is the tech sheet
http://www.servicematters.com/docs/wiring/Tech%20Sheet%20-%204454766.pdf
Unplug the unit
Open it up
Clean the edge connector.
