error F05
I start the washer and after it fills with water I get the F 05 error. I can make it proceed with cycle by hitting cancel once and changing the wash time then hitting start.
Internet site conflict about weather my model has heater or not. If it has no heater then it must be temperature sensor or relay. If it has a heater then where is it? Front, Back, bottom or top.
The diagnostic test runs and passes without a hitch. I would think since it checks the temperature sensor and passes it might be a relay.
Any Ideas?
