evaporator
can someone tell me why my evaporator freezes up on my side x side GE fridge
When the compressor is running, unplug fridg and remove motherboard cover in the back.
Locate the 3 pin power connector and unplug it. place a wire jumper between the connector mating pins labeled line and def. Plug it in, if you get defrost, replace the motherboard, if not replace the defrost terminator clipped to the evaporator and verify the heater is good.
thks checked out and replaced thermister on evap and its been working good for two days now. fingers crossed!
