Extra Rinse
Extra rinse does not work
Open the control panel and check continuity of the extra rinse switch. This is the exact same switch as your fabric softener switch if you just want to try swapping them.
http://www.appliancepartspros.com/whirlpool-cycle-switch-w10168257-ap4346331.html
If the switch checks out ok, the timer is faulty.
http://www.appliancepartspros.com/whirlpool-timer-w10177827-ap4364716.html
Eric
OK, I suspected that. Now, how do I get to the control panel. Other Sears i have had were straight forward
OK I suspected that. Now how do I get to the control panel?
Eric, Thank you! You will not believe what a dummy I am. Either the extra rinse never worked or the contact block vibrated off, but the switch was not connected. Got it fixed.
