this washer i set it to wash only using one rinse, and once it does the whole cycle instead to stop it keeps running to a second rinse.
Sounds like the 2nd rinse switch is stuck. Replace it and see if that doesn’t fix things.
Switch and timer are already replaced
You probably have a faulty load sense switch. This is your user panel fabric softener switch but it’s actually a load sense device with integral water level pressure sensor. It is a high failure item and one symptom is that it begins to add water after the final spin cycle.
http://www.appliancepartspros.com/whirlpool-switch-sen-w10292584-ap4501024.html
Eric
Thanks Eric I will try this switch.
