f-1 error code
customer with maytag range with f-1 code ,comes on intermitantly , sometimes in middle of night with oven off. if customer cancels ,it corrects itself , sometimes completes cooking.i installed new clock which is complete with touch pad , problem persists . clock # 74008108
yup ,i already returned clock, will be recieving new clock on monday, will keep you informed .thanks Gene ----regaurds , Murray ,oh by the by i have a customers washer ,that i will be installing door boot gasket ,model gcvh6260sww, any instructions on installation ,thanks
Hi Gene . hope you are well. i removed new clock which would work well while cooking , then soon after would show F-1 . it is doing the same thing as original clock. , i installed a second new clock. its also beeping F-1 soon after cooking is done, thats 2 new clocks ,what else might it be? only beeps f-1 after cooking is done +oven is turned off ,it cycles on+ off at set temperature. if set to 400 ,it will preheat to 400 . bake element will go off ,then go back on when temperature drops , it will retain 400 degrees. a bad batch, or somethin else going on.clock # maytag 74008108. this clock is complete with touchpad +overlay thanks
