After beginning autocleaning of my maytag oven it began beeping and flashing F1, and the door was locked. I searched around the web and found many similar F! stories and good instructions on troubleshooting. I diagnosed according to one technician and determined that the ERC(clock) was the culprit. So, I replaced the clock. Still - F1. So, I replaced the door latch unit. - now i’m out arount $200 and still have the blasted F1. I’ve read that it could be the oven sensor unit? I do see that the wires on the door latch are pretty brittle. Whether they are still good - don’t know?
I called the appliancepart pros, who supplied the clock unit, to ask if they’ve had the replacement units themselves go bad. They said they are tested at the factory. Another place says to remove the ribbon connector from the clock circuit board and diagnose from there…For the life of me I can’t figure out the trick to disconnecting the ribbon connector and have quit trying for fear of breaking this very expensive unit…
Anybody have any suggestions- or should I bite the bullet and call the maytag man?
Jim in Prior Lake Minnesota
