We had a power surge, bump, etc. during the night. I reset the clock in the morning and all seemed OK. The ceramic cook top functions OK. However, went to use the oven and when I touched bake the lock light began flashing. I tried broil and the same thing happened. I then locked the door and tried to initiate the self cleaning cycle and after a few seconds I would receive the error code f9. The door lock mechanism appears to work perfectly. The door lock switch I tested for continuity and when the switch is pressed ohms read 1 when not depressed the meter reads nothing. I have cycled the power on and off several times to no avail. Help!!!
Hi.
Try to unlock the key pad:
press STOP TIME and CANCEL at the same time for 5 sec.
If that doesn’t help - replace the clock/control board
Here are the breakdown diagrams and http://www.appliancepartspros.com/partsearch/model.aspx?model_id=48561
Thank you. Post the results.
Simon.
I already tried to unlock the key pad. I have ordered the clock control board. I will let you know if it works. Thanks
You are welcome.
Simon.
I forgot to ask how do I get to the control board to replace it???
Hi.
Unplug the unit.
Remove the rear control panel cover.
Simon.
Just got the Control Board changed it in 10 minutes and oven works great, Thanks again!!!
Jim
You are welcome.
Simon.
