Oven control panel very dim and beeping. None of the oven functions work. It has been unplugged and plugged back in (no-joy). I can turn wrenches and screwdrivers but not much on diagnosing or using electrical testers. Any help would be appreciated.
So I replaced the part you suggested. It did make a difference:
The clock area lights up
The buttons work
The Oven warms up
However after a while the oven shuts off and F-7 lights up and starts beeping again.
Ocassionally "TIME" flashes
So now what?
— Begin quote from Ardvaark;479865
Shorted key error. Replace control AP4088560
Ardvaark
[LEFT][COLOR=#000000]So I replaced the part you suggested. It did make a difference:
The buttons work
The Oven warms up
So now what?
Read more: http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/261262-f-7-error-code.html#post487224#ixzz1SIwwQH4y
http://forum.appliancepartspros.com [/COLOR][/LEFT]
Please replace:
Keypad errors can be either membrane or control panel. This part is the membrane keypad. Can you return the computer module being that it was not the problem?
Ardvaark
Does this part already have the EOC in it? I am not sure if I can send it back. I can always try ********.
— Begin quote from Ardvaark;487603
Please replace:
Part Details - WHIRLPOOL Switch Membrane, part number: AP4088736
Ardvaark
This model number SVE47600W shows a separate keypad with ribbon cable. Sorry about the incorrect diagnosis. The F7 on those types of ranges can be either part. My experience with those have mostly shown bad computers with the rare exception or two such as yours being the part I described above, the keypad assembly.
Ardvaark
Is there a different part number for the white board?
— Begin quote from Ardvaark;487745
Ardvaark
