Have a Jenn Air SVE47600W. When using the oven it flashes FC then F- and beeps. Oven will heat to about 300 degrees then receive error code. What is the likely culprit?
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=SVE47600W
Below is a service manual
You will have to join the site and be logged in to be able to download it.
Also it covers many units so you have to be careful to ensure that the section applies to your unit.
http://appliancejunk.com/forums/index.php?action=downloads;sa=downfile&id=385;t=1413712560
This will probably be a pain to find as it is a communication error.
The first thing to try is unplug/remove power from the unit for a couple minutes to see if the unit will reset.
If that does nothing then try the following.
Connector Cleaning / Checking
Unplug the unit
Open it up
Clean the edge connector. Use electronics contact cleaner or isopropyl alcohol.
If that does nothing then the problem is most likely on a board.
Check the board for overheating etc.
Check the solder side for bad solder joints.
Often they are a duller silver color and/or have pin holes.
gently wiggle the components/plug/receptacles white watching the solder side of the board to see if it’s leg moves in the solder.
