I have a Jenn-aire model no. ww27430w. The oven will go on for a matter of seconds before giving an "F" code. No number follows, just "F". Any suggestions? I had replaced the control panel about 2 years ago. Thanks
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=ww27430w
Here is a manual
http://www.servicematters.com/maytag_library/docs/16010312.pdf
Note that is covers many units so you have to use extra care when reading it to ensure the info applies to your unit.
Looks like a F code is a communications error re: a real pain.
Connector Cleaning / Checking
Unplug the unit
Open it up
Clean the edge connector.
This thing has lots of connectors so will take some time to clean and check them.
Thanks for the help. I took apart the connections and cleaned them with a qtip and alcohol. I also inspected the J2 wiring but found nothing. The J2 wiring does not seem to be a harness or ribbon cable but about 8 individual wires band together running between the boards.
I put in back together and fired it up but started to get the f code again. I guess I will try to replace the clock / board as a next step?
