F1-1, F1-2, F1-h
We have a Maytage Gemini that has been throwing the F1-1, F1-2, and F1-H errors. The F1-1 and F1-2 appear to be Runaway Oven errors according the manual, what does that mean exactly?
Also, the F1-H was only thrown once and it was months ago.
Because of the other two errors I was considering replacing the sensors in both ovens, see what happens, and if that doesn’t take care of it, replacing the control pad.
I’m somewhat confused about the sensors as there appears to be a long and short for this model, but it isn’t apparent from the diagram that there is a difference between the two sensors in the oven and which sensor you’d need.
[FONT=Arial][SIZE=2][LEFT]Fault Suspect Failure Area Correction When Checked[/LEFT]
[/SIZE][/FONT][FONT=Arial][SIZE=2][LEFT]
F1-1 Runaway Cook Upper Oven Check the sensor 1050-1100
ohms, wiring, control
Every 6 seconds that the
control sees the latch
unlocked.
F1-2 Runaway Cook Lower Oven Check the sensor 1050-1100
unlocked
F1-H EEPROM Read Error Replace Control Anytime[/LEFT]
[/SIZE][/FONT]
Any insight is appreciated.
