f1 again!
Ok, this is the 4th time since I have had my oven that I have gotten the dreaded F1 error code. :frowning: At least I (somewhat) know what the problem is. The last 3 times I have had a repair man come and fix the oven. At this point, I think I can do it myself!
However, I am a bit fuzzy on the difference between the ERC/clock and the control panel. From what I understand, the "control panel" is simply the black glass front and the "ERC/clock" is the "box" located behind the control panel with all the wires plugged into it. Is that correct?
My receipts from prior service show the following was replaced during the service calls:
3/2000 Part #7721 P041-60 Panel Control
2/2003 Part #7721 P041-60 Touch Panel Control
2/2005 Part #7601 P214-60 Clock
Were these the all same parts? Or was it the first two times the Control Panel was replaced and the last time the ERC/clock?
Help would be greatly appreciated! Thank you.
[FONT=Times New Roman][SIZE=3][COLOR=#000000]We have the same oven (Jennair W131B) and the same F1 problem. The last time (a few years ago) we had the F1 error code, we had the control panel (Maytag 7721P041-60) replaced. The oven is not heating correctly. A couple months ago, we had a repairman come out and he told us we needed to replace the clock but said the part wouldn’t be available until 2010 - not a good answer. Now, just today, we starting getting the F1 error code and beeping - similar to what happened last time when we had the panel replaced. So, do we need a new panel or a new clock? Or do we have multiple problems?
[/COLOR][/SIZE][/FONT]
