Shortly after we attempted a self-cleaning, our JennAir range began beeping and displayed an F1 error, which will not go away. I researched the error code online, and found that it could be the touch pad or the ERC. I disconnected the ribbon strip, powered the range back on, and the F1 code reappeared immediatley. This seems to indicate the ERC. My question concerns which part I should order. Is the ERC called the panel control, part # A375454, or is it the clock with overlay, part # 74008112?
Am also wondering if this is an easy part to replace.
The clock with overlay arrived today, I installed it and immediatley got the F1 error upon plugging the range back in. I am sure it is wired correctly as I took digital pictures of the connections before removing the old part.
Any ideas?
