f10 error
I recently replace the eoc on my fridgedaire range/oven then afer a few times of use the f10 error code tripped again any suggestion or what the next step would be
Hi.
Please provide the model number of the unit.
Simon.
Simon, here is the model PLEFM399DCA
Sincerely, Jeff
Hi.
The F10 code means the over temperature conditions. most likely the temperature probe is bad.
To test it you need a multimeter set to 10000 ohm.
Normal resistance is approx. 1100 ohm at room temp.
The sensor 316490001
Here are the breakdown diagrams and http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5148490
Thank you. Post the results.
Simon.
Simon I ordered and replace the temp probe and used the oven 3-4 times with no error codes. Thanks for all of your help
Sincerely, Jeff
You are very welcome.
Simon.
