About 2 of 3 loads I have an SD error code. I have twice in the past 3 days had an F21 error code. I understand from the manual that SD is suds and F21 is a drain problem. I checked and I don’t have a clog in my drain pipe in the wall. The water is exiting the washer slowly and it seems to be taking a while for it to completely exit the washer. Any suggestions on what I should start with? If the pump were to be going bad, would there be any water at all coming from the drain hose? Is there possibly a clog in the hose and how do I check that?
Related topics
Maytag washer SUD and F02 code - bad pump? | 7 | 18491 | October 27, 2012 | |
Sud and F35 Error still. | 1 | 2232 | September 2, 2015 | |
Have a suds and F35 code | 1 | 442 | November 11, 2017 | |
Sud/f35 error. Tried everything, now what? | 1 | 1088 | June 1, 2014 | |
maytag washer keeps saying code 21 | 2 | 2491 | February 1, 2011 |
