F7
getting a beep, set clock and then goes to F7. replaced control panel and does the same thing?
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5205635&diagram_id=25101424
Could not find a Model Number with the second 0 in it, the above is for a JKP20BF6BB
The control panel on this unit looks like all it is is an overlay.
F7 comes up as a stuck key error and the actual keys are on the control board (erc) which is Item 16 in the "Control panel" section.
replaced the control panel with a new one and does the same thing. do i need to replace the front panel with the ribbon
