Fabric Softener Dispenser
During a normal wash cycle the fabric dispenser will not empty. I replaced the solenoid and it still does not dispense. When I enter the service mode the solenoid works and sends water to the dispenser.
[COLOR=#333333]
If you open up the dispenser valve in Service Mode with water flowing to the Softener reservoir it will not flush out is that correct?
If so I think you need to clean out the Fabric dispenser drain hole with a pipe cleaner or something similar. See page 33 of the SM to remove the dispenser top cover…Dick
[/COLOR]
