fabric spftener dispenser
Hello, have been noticing that the fabric softener cup on the top of the ajitator doesnt empty. Softener is still in there after the wash is finished. Any place I should look first. thanks for your time.
Pull the cup out, take it apart and clean it.
thank you Gene, I pulled up on the cover and inside is a funnel with a closed bottom. The cup the funnel sits in, with the slot in it, was filled with dirt. I will try it later today.:slight_smile:
