fh code no water at all
im getting the fh code no water is going in the washer when i start it the tub turns a couple times and after a couple mins the fh fault comes up it wont do nothing i changed the inlet valves and checked all the water lines everything seems ok is it the ccu i have already replaced the pump now this its only 2 yrs old these things should last a long time for what they cost
