machine appears to fill normally , starts to tumble ,then after a couple of minutes stops +reads fh . i can get it to drain completley+ spin normally +finish cycle. i see no visual problem with water valve /how high should waterfill? should it fill past baffle fins in drum?. i was told water valve or flowmeter maybe problem . what is test for flow meter? if water valve or flow meter is ok , might it be pressure switch? by what i am telling you can you determine if any of these parts are suspect? nobody i spoke to seems to think ccu board is an issue.thanks
FH No water detected entering machine or Pressure switch trip not detected. If after 30 seconds the control does not detect water entering machine and then valves will be turned off and the error code will be displayed.
Or
If the control has turned the water valves on and after 8 minutes the flow meter has detected 10.5 gallons of water passing through it, but has not detected the pressure switch trip, the valves will be turned off and the error code will flash.
Press PAUSE/CANCEL twice to clear the display.
Potential Causes
• If there is no water in the unit:
- Make sure that both valves at the water source(s) are turned on all the way.
- Check for plugged or kinked inlet hoses or plugged screens in the inlet valves
- Verify inlet valve operation
• If there is water in the unit: - Verify Drain pump operation
- Pressure Switch Hose is in good condition and properly connected to Tub and Pressure switch
• Verify there is not a siphon problem
• Verify wire harness connections to; Inlet Valves, Pressure Switch, Drain Pump, Flow Meter, and Central Control Unit (CCU)
• Check all hoses for possible leaks
• Verify pressure switch operation
• Verify flow meter operation
• Verify CCU operation
Replace failed component
Tom
yes .i already have seen what you have sent me .this does not answer the questions i asked
Did you take the lower front panel off, and the pump will be right up front. Unscrew the pump cover, and see if there is not a bunch of stuff in the pump, causing it to slow drain. That is a big problem with that washer. Tom http://www.applianceeducator.com
there is no problem with pump. it pumps out normally. customer now tells me it reads hf intermitantly +stops after 2minutes in beginning wash. then at other times it will complete the entire wash as if there is nothing wrong, maybe there is a siphoning problem,i will try replacing flow meter
It is hard to tell from here. Sitting on my perch without my meter, does not help. Tom
— Begin quote from misterfixall;55235
Misterfixall,
What was the solution to this problem. This is exactly what my Duet washer is doing. Any assistance will be greatly appreciated.
I thought you said in your previous post that the pump was OK. I’m a little confused.
Thanks, Eric
Have An Error Code Problem: F2e4. The Oven Intermittently Operates.
To Get It To Work: Pull Range/oven Out From Back Wall, Tap Back Of Stove By The Light Console. Hit Cancel And Then Bake. It Will Come On… And Then Stop Working. The Is An Annoying Intermittent Oven Problem…any Suggestions
The missus seemed to have in overloaded the machine with floor rugs. Consequently it would not spin and there was a strong burnt rubber smell. The drum would rotate by hand. Today I took off the front thinking it would be a belt malfunction, but it seems to be in good shape. I switched on the machine to spin cycle and the motor starts up, but there is no movement from the belt, also the drum now seems to have locked up.
Help please!
error see next post
Also, I just checked the motor and it is extremely hot after trying to run the spin cycle for only a minute or two. And the belt pulley runs freely.
im getting the fh code and no water is going in the machine it just throws up the code after a few mins of no water ive replaced the inlet valves it didnt help ive recently replaced the pump before this problem came along do you think its the ccu im tired of spending money on this thing its only 2 yrs old
fh code can be caused by a dirty airtrap. small part back of tub near bottom. it is some what opaque, if it looks dirty, it probably is. can be replaced or cleaned by using vinegar or pool acid. use a plastic pail mix pool acid and water (not very much, just enough to cover part) drop in part walk away for an hour. use gloves to remove part rinse, use a bottle brush if necessary and reinstall. neutralize acid by diluting with water and adding a little baking soda before dumping into a toilet or sink. pool acid will eat metal, concrete, your skin, etc.
Airtrap has a tube that attaches it to the flow control, if it is clogged, air pressure can not be created, and it is what the sensor uses to tell the control unit if water is indeed entering machine.
this part is never mentioned in troubleshooting.
