FH Error Code on Whirlpool Duet Washer
Hi,
I am getting the FH error code on my Duet Washer. I have the tech sheet that advises what to check when the code is given. Its given when the washer has water in it, so its not a water inlet issue. I ran the Diagnostic check and it fails on the C:05 step, the washer continues to fill with hot water until the FH code is given, then it seems the drain/pump kicks on and the washer empties. I was advised that the flowmeter was faulty so I replaced it but still have the same problem. Any advice what to look at next would be appreciated.
[COLOR=#333333]Thanks,
David[/COLOR]
Hi David,
More likely the problem is a bad pressure switch and/or clogged pressure hose connected to the switch.
Here are the breakdown diagrams and http://www.appliancepartspros.com/parts-for-whirlpool-ghw9400pw0.html
