fix whirlpool dishwasher
normal wash cycle quit functioning. was told it was control board. put a n ew one in and it functioned the same way. we had been washing dishes with the quick wash cycle and had been getting by but when i first put new control board in the first time we wash it ran the same as with the old board but now even quick wash is not functioning. please advise what my next step should be. i priced the control panel and it may be cost prohibitive? 175.00 Thanks, Eric
the only thing i can think of is to make the door latch is working correctly but i dont think that would be the cause of the problem - wouldnt hurt to check though it could always be an intermittent door latch problem
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=gu1200xtlq0
Here is the tech sheet
http://www.servicematters.com/docs/wiring/Tech%20Sheet%20-%208533399.pdf
As Qtip said, it could be a door latch switch.
Could be that the thermal fuse has blown (Item 6 in Section 2)
Check that the unit is getting power re: wirenuts etc.are OK.
On the original problem, check the keypad with a meter, see the tech sheet.
Normally the way you trouble shoot this type of problem is to check the keypad and if it is OK then you replace the control board. Still a bit of a crap shoot but your odds are better.
You may want to try the following
Connector Cleaning / Checking
Unplug the unit
Open it up
Clean the edge connector.
  1. Always remove power from the machine otherwise you could blow your meter.
  2. Always disconnect at least one side of any device you are checking. This eliminates the possibility of measuring an alternate/parallel circuit path.
  3. When checking for closed contacts and continuity use the lowest scale (Usually 200 ohms). Then try higher scales. This scale is 0 to 200 ohms so if the device you are measuring is 300 ohms this scale would show an open circuit which it is not, you are just measuring outside the scale’s dynamic range.
